Salta al contenuto principale
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
20 Domande Visualizza tutte
Display of message that says 'change the batteries'
My camera keeps displaying a message that says 'change the batteries'. Why is this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@tyiilliamani, Kenzo , Ensure that the battery contacts are clean and install a new quality set of fully charged batteries and if using rechargeable's have charger tested or try another known good working compatible charger to rule it out as an issue. Possible internal clock battery may be faulty (change internal CR1220 battery) or issue with bad components in camera. Find below links to showing the internal clock battery replacement and partial disassembly guide to enable checking of internal wire connections/components/etc. to check for loose, damage, burnt. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Canon PowerShot SX160 IS Clock Battery Replacement
Canon PowerShot SX160 IS Outer Case Replacement
Immagine Canon PowerShot SX160 IS Clock Battery
Guida
Difficoltà:
Moderato
15 - 30 minutes
Immagine Canon PowerShot SX160 IS Outer Case
Guida
Difficoltà:
Moderato
Punteggio 2
Aggiungi la tua risposta
Kenzo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,509
