Salta al contenuto principale
Canon PowerShot SX160 IS Outer Case Replacement
Cosa ti serve
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, immagine 1 di 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, immagine 2 di 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: passo 1, immagine 3 di 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: passo 2, immagine 1 di 2 Canon PowerShot SX160 IS Outer Case Replacement: passo 2, immagine 2 di 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: passo 3, immagine 1 di 2 Canon PowerShot SX160 IS Outer Case Replacement: passo 3, immagine 2 di 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,965
