Salta al contenuto principale
Guide di riparazione, supporto e informazioni sulla risoluzione dei problemi per i modelli MacBook Air con schermo da 13"
20 Domande Visualizza tutte
MacBook not turning on. No charging light on MagSafe.
Issue:
  • Macbook Air (13", A1466) not powering up
  • No charging light on MagSafe
  • No sounds, not even fan
  • Screen will occasionally come on displaying charging symbol or low power symbol
Things tried:
  • SMC reset
  • Disconnecting and reconnecting battery
  • Different charger (non-official but working)
  • Cleaning charging port
Okay, so firstly this is not my MacBook Air and nor do I know much about them, so please keep things simple. This is my friends device, he said it was being used as normal and then it suddenly switched off and never powered up again - the battery was apparently at 40% at the time.
I have tried all the above fixes with no success so far. Upon trying a new charger the charging light initially turned orange before going off again, this makes me think that there is some kind of charging issue. Also the screen occasionally shows that the device is charging before quickly going off again.
Is the issue the charging port, the battery or perhaps something else. Any help and direction would be kindly appreciated as I'm afraid I have little experience working with Macs.
Marty
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Try a new, known good DC-IN board and see if it starts charging. Also, look for previous water damage (stains, corrosion, etc.)
Punteggio 0
Aggiungi la tua risposta
martywild10 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 194
