Salta al contenuto principale
This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
30 Domande Visualizza tutte
Break invalid sim card
How can I break my Sim card for my LG tribute phone asked for a pin got the pin wrong now my Sim card says invalid need to fix ASAP how do i break the Sim card and restore it to its original format
Questa è una buona domanda?
Punteggio 10
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You could restore the phone, that should do the trick....you'll lose all your data...
Turn on the phone by using the Power button.
Go to Settings and then to Backup & Reset.
Tap Factory data reset.
Choose Reset phone and select Erase everything.
Good job! The hard reset is done.
Punteggio 6
1 Commento:
hi is someone can help me ?
my LG is appearing invalid sim card please i need a help
da
Hello, this problem causes when sim card slot doesn't registered in Network, my advice is call your network administration for sim card registration.
Punteggio 2
3 Commenti:
You should register sim slot by that IMEI code in your network operator.
da
how can i do that sir , cause am in Africa , Ghana
da
i really want to use this phone please sir , help me
da
Need help. Took sim card out and factory reset but now it won't read sim
Punteggio 0
Aggiungi la tua risposta
Lisa Cheney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 19,337
