Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Domande Visualizza tutte
Domanda Chiusa
MacBook WONT charge the battery. new battery still nothing
okay i bought this macbook used. he said it needed a new battery.
i ordered battery connector and the dc in bored i havent got them yet. under the battery connector i see a little black and there seems to be green stuff on the pins on the original connector.
just wondering if im waisting my time with the new parts.
also if i put a charged up battery in the machine it works just fine it simply will not charge it.
the magsafe led is always dim green with or without the battery.
i did all the resets pram and what not.
thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I'm not sure you've asked a question here. I'd come back after you've installed the replacement parts. There's really nothing to tell you till you do.
Punteggio 1
2 Commenti:
but i just want to know how to see signs of water damage.
da
The newer Unibody MacBooks have liquid sensor indicators so Apple factory techs can tell if it's been wet. They did this because seeing the results of water damage is almost impossible.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 948
