Salta al contenuto principale
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
How to make my phone work again?
My phone suddenly died. I was working normally on my phone then it suddenly went black.
The phone won't turn on again, and there is no indication of life at all.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Have you cheaked your battery ?
da
when I was playing Roblox and then when I was done I turned off my phone and when I turned it on again it said that stock android has stopped can you pls help me bc I really want to play Roblox again with my friend’s thanks
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Few things to try:
  • Verify that your phone has a sufficient charge.
  • Connect your original charger to your phone.
  • After a few minutes, try to turn on your phone. If it doesn't work, try another charging cable. Try mains and USB charging.
  • Verify that your phone, charging port, and battery contacts are not damaged.
  • Carefully inspect your phone's charging port and remove any debris.
  • Remove the battery.
  • Carefully clean and inspect the gold contacts on both the battery and on your phone.
Attempt a forced restart of the phone.
  • Press and hold the Power key for 30 seconds.
  • If the phone starts to power on, release the Power key.
Punteggio 3
3 Commenti:
My phone works but doesn't go past the logo, it will then either stay stuck there or restarts itself
da
my phone is doing the same thing
da
My android phone won't let me call out or get phone calls help
da
Aggiungi la tua risposta
Shay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,796
