Salta al contenuto principale
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
85 Domande Visualizza tutte
Left and center channel swapped
Hello, I am having a problem with my HyperX Cloud 2. I had to buy a new jack, and now I am having an issue with the sound channels. The right one is fine but the left channel is played like the center and center is played only from the left speaker. Microphone and right channel work perfectly. Any ideas?
Thank you.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You must have wired it wrong. This is what it should look like (make sure the colors are correct):
Hope this helps.
Punteggio 3
2 Commenti:
I have jack with wires already I am just connecting the wires together.. But thanks for help I had the wiring wrong and it works now :)
da
Glad I could be of assistance.
da
Aggiungi la tua risposta
Jakub Setnicky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 927
