Salta al contenuto principale
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 Domande Visualizza tutte
Call and sms not working
Blackberry Classic
Not able to phone or sms. However it works fine for mails and whatsapp in wifi mode
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Risposta Più Utile
I would first try your SIM card in a known working phone. I would also try a known working SIM in your blackberry.
If you can get SMS and signal on the other phone, then something is wrong with the blackberry.
Punteggio 1
2 Commenti:
Tried both. SIM card is ok. Seems something is wrong in the phone
da
Ok, try downloading the blackberry desktop software to reload the OS. You should use this to backup the phone first. If this still doesn't work, then there is some hardware failure.
da
A blackberry phone? Maybe you can try to shut it down and then turn it on mins later.
Punteggio 0
1 Commento:
Tried. Still not working
da
Mobile marketing has many proven results it helps in improving reputation which drives more traffic to the business it is the best marketing strategy I have seen which drives more traffic to the business.
Regards,
kevin - Bulk sms
Punteggio 0
Aggiungi la tua risposta
Sivakumar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 384
