Salta al contenuto principale
Repair information for the Gaggia Classic Espresso Machine. Can also be helpful for repairing a Philips or Saeco espresso machine.
Steamer no longer works
Following what sounded like a burst of water falling on a hot surface inside the machine, the steamer worked briefly then gave up entirely: no water, no steam, no sound. The coffee portion of the program still works fine. Does this sound like a failed part that can easily be replaced?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If you not descale the unit frequently, a thick layer of scale is created on the walls of the boiler.
Let’s say you never did descale the unit for like 2 years, and suddently decide to descale it, the thick scale build will unstuck from the walls forming big chips of scale on the buttom of the boiler, when you opening the steam knob, some chips may get stuck into the pipe/valve, reducing the pressure.
You should open dismantle the compleet valve and maybe keep it on a descale solution for some time to resolve the p problem.
Punteggio 0
Aggiungi la tua risposta
DCA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 235
