Lamp replaced still no picture
I replaced lamp with new one. Still no picture. The lamp just flickers and makes crackling sound
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 126
@ged52 did you check the ballast as I suggested on here No picture even though lamp replaced
da oldturkey03
Not yet. I need to get a meter.....the one I have has a bad wire. When I check it can I insert the probes into to lamp connection points or should I check it some other place for the voltage. I believe the proper voltage reading should be 280 V. Is that correct. Thank you for your advice.
da Greg
I put a meter on the connectors for lamps and it blew my meter. I had it set on 700V. Not good
da Greg
@ged52 the voltage between the power board and the ballast is 220 to 440V but on igniting the ballast can exceed 1000V
da oldturkey03
I checked the voltage to the ballast assembly coming into the board and it is Ok.
da Greg
Mostra 1 altro commento
