Salta al contenuto principale
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Domande Visualizza tutte
Why is my battery runs out of charge
'''I'm having a trouble with my Samsung Galaxy S4 regarding its battery .. it runs out of charge so quickly and I can't work comfortably with this phone as I always need to carry the charger in my bag .. are there any solutions to this problem .. knowing that my battery is not original
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
you may want to check to see if theres any apps that are unduly draining power security 360 will shut down apps that drain power and helps with battery life . but if your not getting a days life from the battery then you probably need to get a new one .
https://www.amazon.com/s/ref=nb_sb_noss/...
http://www.ebay.com/sch/i.html?_odkw=htt...
Galaxy S4 Battery
Immagine Galaxy S4 Battery
Prodotto
Galaxy S4 Battery
$24.99
Punteggio 6
3 Commenti:
i will try the app and i will see if it is helpful or not .. thank you
da
I have a S4 mini with the original battery and i sometimes have the same issues. The battery was being drained in 5-6h on idle. First time it happened after i installed a load of apps.. after a factory reset it was fine. nowadays, even though i hope i got rid of the faulty app, it still happens sometimes.. out of the blue.. like .. 1time/2 months. An LG flex does the same thing. It's prob the apps. Can't rule out the battery though...
da
i think it's a blemish .. not just in my phon but in all samsung g s4
da
You need a new battery, batteries wear out over time and need to be replaced. You can get one from almost anywhere, like ifixit, eBay, etc.
Punteggio 3
7 Commenti:
where can i buy an original battery ??
da
From ifixit, these are one of the only places you can get actual OEM battery.
da
how long a full battery works ?? with using wi-fi and apps ?
da
When i had my galaxy s4, it would get about 1 day and a half from 100 to 0.
da
a day and half !! how ?? there is no smart phon can work 1 day and half
i mean you use the phon 36 hour successive ??
da
Mostra altri 2 commenti
If you know its because your battery is fake so the only option is to buy a new one orrr carry a power bank to supply power and the same time being portable...
Test your battery condition by some apps just to make sure its dead or not
Punteggio 1
4 Commenti:
i have done it before ... i mean i test my battery condition by "
Battery Widget Niveau Charge %" app and the results were good ... so what's the problem ?
da
How much your phone lasts with full charge?
da
And do u have a genius or original power plug?
da
it depends .. i can't be sure .. i don'y know if i have an original or genuis .. but i think it's original
da
Aggiungi la tua risposta
tony sarniko sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 403
