Salta al contenuto principale
The Bose SoundTouch 10 is a compact and portable speaker measuring just over 8 inches tall and released in late 2015. It is Wi-Fi and Bluetooth-enabled, and it comes with 2 color options - black and white.
Why is the volume not adjusting?
My music is playing and I'm pressing the +/- buttons but the volume isn't changing. How can I fix this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
The buttons might be dirty or dusty. Try wiping them off or spraying compressed air to clear any debris. If that doesn't do the trick, the issue may be internal. Try repeating the step above but on the inside of the speaker where the back of the buttons are. Now, if that doesn't work, there may be an electrical connectivity issue, which would need to be professionally repaired or replaced.
Punteggio 0
Aggiungi la tua risposta
Sean Reece sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 290
