Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Ipad Mini Shaking Screen
Hi! I really really need help! My Ipad Mini won't stop shaking! I tried rebooting it by holding down home and sleep button for couple of seconds but still not work! My dad went to a store to get my Ipad fixed but dad said that they can't fix it! My mom wouldn't let me use it since I got headaches after using the Ipad... I've been searching a week for answers but none of them work! Please help me,I'm crying and I have nothing to do right now
Questa è una buona domanda?
Punteggio 1
4 Commenti:
Shaking how? Device is vibrating? Is the scree physcally moving around, I require more details
da
Hi, Would replacing the LCD screen or digitizer of IPAD mini solve the shaking display issue? Anybody who tried? Please share your experience. Thanks
da
Yes. Most of the time, replacing the LCD would fix the issue with shaking. Shaking is from an unstable or damaged LCD which is the component you physically look at for your display. Install a new LCD and you will be back to normal. If issues persist with a KNOWN working LCD, then it would need board level repair but that is very very uncommon. We have an iPad in here currently that has white screen issues that goes back and forth. Not the same issue but similar. Replaced the LCD and back to normal. Here to help if needed further. Thanks much :)
da
Thanks @theiphoneguy007. The Ipad Mini LCD screen is physically intact and not broken as it's rarely used. The shaking display started last year from nowhere. I hope Apple still produce LCD for this old device. Thanks!
da
Aggiungi un commento
2 Risposte
Sounds like you need a new LCD screen. When you took it somewhere, did they actually try and replace the LCD screen itself? This is what you will need to do to get the LCD to stop from shaking. I doubt that it is the motherboard causing this issue but you never truly know until after the repair. iFixit has lots of guide depending on your model. If the device is under a year old, you can try Apple warranty.
Punteggio 0
Try replace ur lcd to fix it. Because i will try my ipad mini replace new lcd and yes!! No shaking at display hehe
Punteggio 0
1 Commento:
Is there no option than that ????n plzzz
da
Aggiungi la tua risposta
Ariana Blythe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 5,993
