Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacement screen doesn't work
My wife dropped her iPhone 6 and the screen started getting lines through it. It still worked and the glass was undamaged. I checked the ribbon cables but everything was connected. Although ironically after putting the phone back together her front camera and speaker didn't work so she had to make calls on speakerphone and only take pictures with the back camera. I bought an "OEM" replacement screen assembly with the home button and camera already installed on Amazon and followed the guide (I've replaced her phone screen or mine at least 4 times although not before on this model) and it all went exactly as planned but when I turn the phone the screen comes on like normal but the will go black and turn back on a couple times and then nothing. I have to remove the battery ribbon cable to get the phone back off. I'm guessing it's a defective replacement part. If it's OEM it certainly doesn't quite fit as tight, it fits really well but it doesn't have the same satisfying snap the original does. Any tips? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are a lot of bad screens on Amazon, you have to be careful.
I would try to connect just the screen (LCD and digitizer flex) and see if that works. Small parts can be problematic, especially when already mounted on the replacement screen. You could always transfer over your camera and speaker from your original screen if that is the only problem.
If you are unhappy with the quality of your amazon screen, I would seek a refund and get one from a better supplier, such as iFixit.
Punteggio 2
Aggiungi la tua risposta
Phil Schroeder sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 75
