Salta al contenuto principale
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
Phone not working (Nothing can be seen)
Dear Community,
after a time I tried to use my old Lumia 1520 again. At first it didn´t work at all, so I bought a new battery and assembled it. Nevertheless the phone did not work. When I tryed to switch it on, nothing could be seen at the screen. The only reaction was a flashing of the three lower buttons. Though I can acess the storage and reset it via PC, nothing is working. In my opinion the mainboard is damaged. Any help concerning a new mainboard or other troubleshooting suggestions would be grateful.
Count Omega
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks for the quick response. In my opinion there could be also the mainboard/screen connecction be damaged as sound ( locking, charging) are working. I´ll try your solution.
Count Omega
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@count_omega ,Count Omega, Just a thought. Perhaps disassemble the phone and clean all connections(Qtip dampened 90%+ Isopropyl Alcohol) and then reset the connections to be sure of good contact and wires not pinched/broken. While phone is apart use a magnifier to inspect board/components/connectors not(loose,damage,burnt)/solder joints(cracked,etc.) and check that battery is indeed charged. Below is a disassembly link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nokia Lumia 1520 Teardown
Punteggio 1
Does it make sense to remove the chips shielding following the instruction? At the whole phone I couldnt recognize any damages.
Punteggio 0
Aggiungi la tua risposta
Count Omega sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 127
