Salta al contenuto principale
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
80 Domande Visualizza tutte
Will not turn on, no image on the screen.
will turn on, theres a green light indicator but no image loading on the screen, tried removng batterry and resetting by holding power button but wont do, when try to remove and re insert battery, green light indicator automaticaly turn on w/o sliding the power buttton on
Questa è una buona domanda?
Punteggio 5
1 Commento
franklyn72001, did you get it fixed?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
try to turn your psp on using charger and if you can connect it to a tv and see if the display turns on if it does then take it off display and if its still black screen then that means you have a backlight fuse problem.
Punteggio 1
buy a new battery
Punteggio 0
Aggiungi la tua risposta
franklyn72001 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,148
