Salta al contenuto principale
Repair guides and support for cars and trucks by Dodge.
Power windows dont work
All Power windows only work from driver side panel. but driver side window doesn't work from panel
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
@pernellp2 .Pernell, You did not state your year,etc. First check the power window lock out switch on drivers door switch panel, make sure it is not in lock position. Other things it could be are the window lock switch defective(contacts defective, see link below) if equipped, master control on drivers door defective(test with DVOM) or possibly wires pinched/broken in the wire harness/loom between door pillar and door frame. You can also test your drivers side switch as possibly defective or wire/plug loose or damaged at switch/PW motor or possibly faulty PW motor. Find below some other links that deal with the same issue, last link has some diagnostics. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=uDgPcnps...
https://www.youtube.com/watch?v=dMxueIrF...
https://www.youtube.com/watch?v=26JdaFHr...
http://www.ramforumz.com/showthread.php?...
Punteggio 0
2 Commenti:
@lpfaff1 OR the more likely answer is that the switch to make the window go up and down is worn out and needs to be replaced as the OP said that the other 3 switches on that panel work fine, its just the driver door windows switch that need replacement
da
@cam2363 ,Cameron, read the complete question! (((All Power windows only work from driver side panel)))
da
It could also be as simple as a fuse! Don't let the size or the frequency of a probable cause, fool you! Because trust when I say, the fuse can easily fool you. A simple check, either it's the problem or not, but if it is, how much did you just save yourself by making a simple detour off to the fuse panels. Fingers crossed its as simple as that!
Punteggio 0
Aggiungi la tua risposta
Pernell p sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 51
