Salta al contenuto principale
Il Nintendo 2DS è un dispositivo di gioco portatile sviluppato come versione entry-level del Nintendo 3DS con hardware quasi identico, ma senza la funzione dello schermo superiore 3D.
205 Domande Visualizza tutte
SD Card Stuck In Write-Protection (Console Problem)
Hello,
i am having a problem with the console saying the SD card is stuck in write-protection. i can tell you for a fact, the card is not. the slide is at the top and have even tried 2 other SD cards. The other SD cards i have also work fine in another 2DS i have tried.
are there any suggestions how how to fix it? i updated the console and formatted it just to see if that would fix it.
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try to open up and clean the contact pins, they could be dirty and shorting something out.
Punteggio 3
5 Commenti:
Thanks for the reply, i gave it a shot but to no prevail. nothing is screaming out at me that there is anything wrong visually
da
What about the 2 smaller pins to the side?
da
they appear to be fine, not touching each other
da
What about cleaning around the connector? Also has it ever been water damaged?
da
yeah ive cleaned it. it was all clean already but gave a clean as best i could just in case. there is no liquid inside. no visible sign of water damage
da
Aggiungi la tua risposta
James sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,200
