Salta al contenuto principale
The first FWD car to be exported to North America by Volvo
fan is not running
i have a 1995 Volvo 850 series, 2.4 non turbo. My fan is not running either, the relay block has two yellow connetors in the middle, I know these are what control the low and high fan speed. fan test ok for running but when I ground jump the two center relay connectors for the fan speed the fan will not run, acts like there is no power getting to the relay block. thanks, Ken
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@fathertime24 not sure what you mean by ground jump the two center relay connectors . checking the wiring diagram for your Volvo these do not go to ground and shortening those to ground most likely will not accomplish anything. If anything applying a jumper from B1 to B2 on the relay would bypass the control module.
Punteggio 2
Aggiungi la tua risposta
ken sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 364
