Salta al contenuto principale
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Domande Visualizza tutte
How to change right speaker on ACD?
On Apple Cinema Display, how do I change the right speaker? Left speaker is working fine. But the right speaker is not putting out any sound. When I said right speaker I'm referring to the speaker on the right side of the Apple Cinema Display. If we're looking at the display, it would be on the left side. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Left and right are usually referenced when the device is in its operating state. So when you are looking at the monitor straight on, the right speaker is on the right (the same side as the clock in your dock), and the left is on the left (by the apple menu of your dock)
There isn't a tear down on iFixit, but the Apple service guide is linked on their system.
Its not as detailed as the iFixit guides are, but you will be able to fully trip it down following the guide if you scroll about 2/3 of the way through the document. it shows you have to remove specific parts.
Its the document that Apple distributes to its repair centres, so it is pretty comprehensive.
Its found here: led_cinema_display_24.pdf
But in essence, you'll need to remove the glass panel with a suction cup (carefully to prevent damage to the alignment pegs that are on the underside of the glass), then unscrew the LCD panel (torx screw on left and right side), then lean it forward to disconnect the LVDS cable and the backlight cable from the main logic board.
Once that is disconnected, you will see the speakers and their connection cables clearly and will be able to trace them to their ports and disconnect them.
I hope this helps.
Punteggio 3
Aggiungi la tua risposta
Anak Manis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 158
