How much it costs to change a 2008 Range Rover sport front suspension?
Range Rover 2008,sport. It seems there is a suspension problem, front side, it's moving a lot on the road. How much it costs to change it please?
Questa è una buona domanda?
Khaled kouteich, It could be something as simple as a tire low on air or possibly needing an alignment. Check all tires for proper inflation pressure and tires for uneven wear which could be caused by simple alignment required to something more like a bad strut, worn/damaged steering/suspension component. Your best to get inspection/estimates on this repair at a few good local automotive shops, they can supply you with an estimate listing required parts. You could save a lot of money for your self, by searching for the parts needed on line and purchasing, as you will avoid part markup cost and then have installed.
This is just an example below of what you could expect to pay for 2 front struts R&R, if you lived in Michigan USA. (Repair pal link below).
Parts & Labor Breakdown on 2 front struts for 2008 Range Rover sport.
Labor: $559 - $712
Parts: $1070 - $1184
Estimate does not include taxes and fees.
Included Parts
2 front shock absorber/strut inserts
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
@khlkhl there is no way to answer this question. You first have to determine what has failed and does it need to be replaced or adjusted etc. Could be many of thing from ball joints to tie rods and a thousand other causes. So, no way to help you with that like this. Have it checked and get an estimate. Once you know what it is then let us know so we can be of better assistance.
I'd start by checking the parts of your suspension
and see what looks damaged. #5, #9, #14#10 and #17 would be a good starting point. #2 and #7 are also possibles. As you can see there is a lot going on with your front suspension and a guess is never good.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 39
Tutti i Tempi: 6,470
