Salta al contenuto principale
Philips Marathon Bagless vacuum cleaner HomeCare with TriActive nozzle.
How to fix the cable rewinder
Hello,
The cable does not rewind completely when i press the botton. I would like to know how to fix this.
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@den23 , Den, Rewind spring may of detached from it's retainer. Use the link below(Philips Marathon Vacuum FC9202) service manual, to aid in disassembly of your vacuum to check/replace/repair the auto rewind spring/mechanism. Pg. 6 show's the mechanism in detail. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/108254...
Punteggio 2
Aggiungi la tua risposta
Den sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,426
