Salta al contenuto principale
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Domande Visualizza tutte
Xbox 360 Slim E14/0032 Error
A friend recently came to me with a broken Xbox 360 S, he experienced a lot of hiccups and freezes, after a couple of days the Xbox gone red. So i took a look at it and i got an E14/0032 error. Which means it might be temp sensor related. So i took a look at some options, the first one was an reflow, unfortunately i don't have such equipment or a store nearby to do that. On an other form they recommended to scratch the board (the connection from the temp sensor) as an last resort. I don't know what to do right now, if it's better that i replace the mobo or is there an other solution to this problem?
I already replaced the thermal paste and the Xbox is out of warranty.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check pin 2 of ncp1581g ic for 0.9v this is an enable to turn on the switching output. If not present resolder the resistors that connect line from cpu to enable pin.
Punteggio 0
Aggiungi la tua risposta
DutchTurbo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,224
