Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 Edge è la versione con schermo curvo dell'S6, il modello al top di gamma di allora.
237 Domande Visualizza tutte
How to replace the charging port
I have a damaged charger port and my phone has been dead a few weeks now while waiting on the part, how do i replace it? My screen is ridiculously broken might i add, still usable but shattered i dont know if this affects the process.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
belinda turner, Link below will show Daughter board which contains charge port, replacement. 2nd link is to replacement part(verify part correct for your device/model before placing order or use the last link and select your exact model and find replacement part). You can also do a search for part yourself to get better pricing perhaps. iFixit store also has replacement Galaxy S6 Edge LCD Screen and Digitizer assy. that you can replace at the same time if you wish. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Sostituzione Scheda della Presa di Ricarica del Samsung Galaxy S6 Edge
Galaxy S6 Edge Charging Daughter Board (T-Mobile)
[[ collegamento alle parti non valide ]]
Immagine Galaxy S6 Edge Charging Daughter Board (T-Mobile)
Prodotto
$29.99
Punteggio 2
1 Commento:
Why does it specify t-mobile?
da
Each charging port is going to be carrier specific. Before ordering, make sure you search by your phone's model as written on the back glass. G925T or G925A denote the specific carrier types.
Punteggio 0
Aggiungi la tua risposta
belinda turner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 10,394
