Salta al contenuto principale
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
Panther 10.3, highest version of Itunes possible?
I have an ibook with Panther 10.3. I have one issue with itunes. I am using the version of itunes that came with Panther 10.3. Would I be able to upgrade to a higher version? If so, how high can I go? This version doesn't seem to be able to read the backup discs that I made a while ago on the other computer. It also doesn't give a "recently added" playlist on the ipod, which is really nice. Any advice?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Download the 10.3.9 combo update from apple here:
http://support.apple.com/kb/DL496
This will update ALL previous Panther versions up to the latest OS which is 10.3.9 this will save you alot of time from updating it one version at a time.
This update will most likely update the itunes as well then once you have finished the update go to the apple menu on the top left and run SOFTWARE UPDATE. This will find and install any further firmware that was released after the combo update pack. Just keep running the software update until it does not find anymore new firmware versions.
Punteggio 1
Aggiungi la tua risposta
Sarah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,907
