Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Proximity sensor iPhone6 plus
Hello Guys i have a question about my proximity sensor,
I replace my sensor to an other screen and its not workin properly anymore,
When i am making an call i use my finger to try to lock the screen and it works but when i hold in to my ear it some times go on lock sometimes it does not, can someone please help me out herr
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Usually I find out this is caused by a screen quality issue. The only fix I found was to use a better screen that would make the proximity sensor more sensitive and work properly.
Switching to a preassembled original screen will work too (If you can find an iCloud locked phone to use for parts).
Punteggio 3
1 Commento:
I have no proximity bracket placed on is that a problem? ,
In case not
is there annyway to fix this with a marker like the iphone4 ?? Or are the screens for the trash?
Or is there a possibility that i heaten the flex to long that its damaged?
da
Aggiungi la tua risposta
glennjacobs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 964
