Salta al contenuto principale
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
How do I do a factory reset?
Factory reset for a visual land prestige elite 8qi
Questa è una buona domanda?
Punteggio 10
4 Commenti
I got a used tablet and it will not let me log in to my account to set it up and it keeps asking for a previous email that was sync to it before and I don't know it
da
I accidentally hit the button for the blind I was trying to dim my screen and I hit the wrong button now it talks to me and gives me commands but it doesn't light up I can't get nothing to light up on the screen cuz I hit for the blind and now I can't get back in it to turn it to take it off of the blind
da
Don't know what happened mine. It is not coming on at all. Tried all suggested fixes of holding power volume button. Does not work. How do I n reach manufacturer?
da
How do I factory reset my tablet if my password won't work
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hold both volume up and down buttons together with the power button for about 15 secones, until you see the presitige logo. Pick the option: wipe data/factory reset and then select yes. When it states : wipe data complete, go back to top and choose reboot system. Navigate using volume up down buttons and select with the power.
Punteggio 8
4 Commenti:
What if you are locked out of the tablet how do you factory reset
da
I just did what the original text said and it worked
da
How about if u don't know the password
da
make sure the device is off. Then at the same time hold all three down the power the volume up and down and when you see it come on release both vol buttons and then instantly press them again do not let go of the power . hold for 3 sec and then release all you welcome
da
Hi,
If you have access to the device functions you would go to Settings>Back-up & Reset>Factory Data Reset.
The link below is the PDF version of the user manual:
https://visual-land.com/downloads/androi...
Punteggio 1
1 Commento:
I installed a security code and now the tablet is rejecting it. That leaves me with no way to access the tablet to reset it. Is there a way to be able to bypass this code to reset my tablet?
da
Aggiungi la tua risposta
Denise Jolly sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 9,906
