Salta al contenuto principale
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
How do I change front struts
How do i change front struts
Questa è una buona domanda?
Punteggio 0
1 Commento
jms_skw ,You are putting your question in the answer box, it would be best for you to repost all vehicle details year,make,model, etc and your question/problem as a (question)! This will be seen by more volunteers and may assist answering your question better.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Front struts are easy on a caravan and do not require a front end alignment when done as long as you don't change the tie rod ends when you do it . There are tow bolts holding the strut at the bottom and 3 on top accessed through the engine compartment. If your only replacing the strut then you will require a spring compressor as you need to compress the spring to remove it safely This video will help
https://www.youtube.com/watch?v=ns_IzhfJ...
Hope this helps
Punteggio 2
Aggiungi la tua risposta
jms_skw sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 153
