Salta al contenuto principale
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
Dust Speck Inside Canon Powershot G11 Lens
I have what appears to be a dust spec on the inside of my Canon Powershot G11 lens and I want to disassemble, clean and reassemble. I took it to a shop that looked at it and they are 99% sure that it is not dead pixels in the sensor. They advised buying a new camera because repair would be $100's or find a used G11 without the dust speck and did lament that the G11 is a great camera, had a cult following and it was almost impossible to clean the innards.
Anyway if it is trash I might as well take a stab at cleaning it. Is there a manual that will guide me though the inner world of this cube packed with technology with a hope of being able to reassemble it?
Ed
Questa è una buona domanda?
Punteggio 1
3 Commenti:
I found a Canon Service manual on here that looks like it has what I need.
da
@eddyv question answered, problem resolved? the manual going to work for you?
da
Old Turkey - Manual looks detailed enough; I will know better once I try to put it back together! :-)
da
Aggiungi un commento
2 Risposte
Hello,
Do you have this canon service manual in order to help me to fix a defect on the lens
Regards
Philippe
Punteggio 0
1 Commento:
can you send me please so that i can try this at home. Thanks a lot Philippe
da
probably a sand inside the camera/lens, because i used it during when i sat down in the beach.
Punteggio 0
Aggiungi la tua risposta
Ed van der Veen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 882
