Where is the backup light switch located
can't find the switch to the reverse light on the transmission
Questa è una buona domanda?
@cadillac93, Zentella, On most of the Cadillac's the reverse lights are controlled through the transmission Range Switch/safety neutral switch and computer, switch is attached externally to the side of transmission on the gear selector shaft. Check the links below for more info., the 1st pic. is what the safety neutral switch may look like and the 2nd pic is wiring under the steering column. If need be pop into the Cadillac dealer for more info. and part availability,etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://estimate.myautomatictransmission....
http://www.cadillacforums.com/forums/cad...
thank you. it did help me to narrow some switches i seen. i am cleaning everything under the car so i can see better. still no reverse lights also i notice the car has a car starter and is connected to the car wiring? i post some pic soon.
Zentella, thanks for posting back, good luck with your repair.
My 1993 cadillac fleetwood had a problem with the reverse lights not turning on once i put the gear in reverse. I search for a good minute i found out that the causes of that problem can be many reasons for example; fuses, relays, neutral/safety switch, reverse light switch that is on the steering column. Got an email with information about switches and reverse lights problems and how to test them from L Pfaff. also a member from this page it was allot of help. trying to find anything by your self may not be a good idea. uncle of mine is an electrician, he can by and tested the ground and power. we figured the reverse light connector was old and had lots of rust and it was interrupting the electric current to the reverse lights, we cut the connector and connect the cables direct which it fixed the problem.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,628
