Salta al contenuto principale
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
How can I remove a CD stuck in the CD drive
A cd was already in the cd drive and another cd was put in the same cd drive how can i remove them
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Step 1 (if you are truly lucky): Boot up while holding down the trackpad button to eject the CDs.
Step 2: Access the drive itself, remove the cover, and remove the CDs.
Good luck!
Punteggio 3
I have had this problem with a CD with a stick-on label. Answer:stick your finger nail into the CD slot and pry the case up gently at the same time you hit the "eject" button or command- E. Works for me!
Punteggio 2
Aggiungi la tua risposta
Gary Chisolm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,144
