Salta al contenuto principale
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Phone Not Turning On
My phone got off automatically! For some time only samsung logo was seen after that there is nothing! I tried changing battery bt didnt work! There is nothing while charging except phone gets heat up.! Did i lost it ! please help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you tried getting to the boot menu of the phone by holding the Volume up button and the power at the same time.If the boot menu is working try to do hard reset or try to restore it to its original firmware via kies.
-Hard Reset
1. Hold the Volume Down button
2. Press and release the Power button
3. A menu will then appears
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6 Select Volume Up for YES and Volume Down for NO
-Guide on restoring original firmware with kies
http://www.samsung.com/ca/support/skp/fa...
Punteggio 0
2 Commenti:
Already tried
da
Phone is not starting!!!! So unable to hard reset it.
da
Aggiungi la tua risposta
Kashif Abdullah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 21
Tutti i Tempi: 115
