Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Will my phone still work?
I had an iphone 6 for about a year or so and it has seen better days. The phone is currently missing a screen, front cam and a home button. On top of that, the battery shorts out (charges to 100% then dies 10 seconds off the charger). Is it possible to replace all these things and maybe revive the phone? Or is it completely done for? There is still pictures, numbers, notes and stuff on that phone. I would like to have that phone working again, but if it's done for I would like to know that it is.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You can get all those parts replaced. Just no touch ID at the end because the phone only accepts the home button that came with the phone to have working touch ID.
So basically you will need to get the following:
- Screen with preassembled parts (home button extension cable with Metal plate, earpiece speaker, front camera assembly)
- Replacement battery
- Replacement home button
iFixit sells all these parts and honour their warranties very well. You can alternatively get these fixed by a independent mobile phone repair shop or buy the parts from somewhere like eBay / etradesupply and etc if you want to get them cheaper for DIY. Make sure you are buying from reputable sellers and are getting the right parts. Don't go too cheap or you risk getting faulty / DOA parts (though the chance of DOA parts are still there on reputable sellers).
Punteggio 2
Get them on eBay for less then $50 it's not that hard to fix battery is mildly hard
Punteggio 0
Aggiungi la tua risposta
YuhboiJuice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 65
