Salta al contenuto principale
Hewlett-Packard ha iniziato a produrre personal computer di tipo laptop nel 1993.
3332 Domande Visualizza tutte
Why is it that my PC shutdown after 8 seconds when start booting?
My HP Probook Laptop doesn't boot again. it turns off after 8 seconds when i press on power button. i have tried several options such as ; disconnect all peripherals, remove AC Adapter and battery, and then press on power button for about 15 seconds and it worked for the first time.
but after i have shutdown the laptop and start it again, the problem reappeared. now i have tried the same method repeatedly but its no more responding. please what should i do. Help me.
Thanks
Questa è una buona domanda?
Punteggio 3
4 Commenti:
did this just happen all of a sudden? Did you spill any liquid or mess with anything inside
da
Perhaps it's overheating? Are the fans louder than normal?
da
Did you remove the CMOS battery and main battery, wait 20 min and put them both back
da
Yes the fans are louder than normal
da
Aggiungi un commento
1 Risposta
My PC had the same problem. It disappeared when I performed a CMOS-reset. Such a reset is very easy to do. I would recommend looking up the procedure in the motherboard manual of your computer.
It’s often a matter of switching a jumper for a few seconds and putting it back.
Alternatively you can remove the motherboard’s battery for a few minutes.
This operation should not mess up your computer, all it does is resetting the motherboard to its default settings. That being said, I still recommend looking up the procedure in the motherboard manual of your computer.
Punteggio 0
Aggiungi la tua risposta
Gideon Katman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 119
