tripple-clicking your home button will invert the colours, and holding it will activate siri.
This could be a short in your flex, on the connector, or a mechanical pinch of the button.
-i would suggest removing the new screen, but keeping it plugged in. test the button with the screen apart from the frame. if this fixes the issue, it is a mechanical pinch, and you need to sort out how it fits in your frame.
-be sure you have taped the digitizer circuit across the bottom with electrical or Kapton Tape.
-make sure the home button slides nicely between the LCD And the Frame.
your home flex ribbon may be shorted, in which cas you will need to re-replace it
You could have the connector to the Motherboard having a loose pin. in which case you will either need to realign, or replace that connector.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
