Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
iPod Touch 4th Generation Screen LCD
Hi,
In my house, not a hair dryer nor a heat gun exist and I don't really feel like going out to buy one. Is there something I could use to loosen the adhesive that is NOT a hair dryer or a heat gun? Could I use an oven if so what temperature?
Thanks,
Dawgie
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@ipod5_and_ipod4 ,Dawgie , Do you have a heat pack/hot water bottle or something similar you can heat up in the microwave or very carefully in oven and then lay this over screen to loosen adhesive(check often as you do not wanting to get too hot). You can even heat up uncooked rice/grain in a pan and pour it in a sock and then tie the open end for home made heat pack. heat pack ideas links below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.instructables.com/id/Homemade...
http://fellowfellow.com/diy-heat-pack/
Punteggio 3
2 Commenti:
Thanks I never thought of that!
da
Dawgie, Welcome, thanks for posting back, good luck with your repair.
da
Aggiungi la tua risposta
Dawgie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 122
