Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
210 Domande Visualizza tutte
Batteries interchangeable between series?
Are Apple watch batteries interchangeable between all the different series? Say I need to replace a 38mm apple watch battery (original), can I use a 38mm battery for series 1 in the original?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Can I use the Apple Watch battery from a series 1 for a series 2
da
Hi,
Is the apple watch series 1 and series 2 batteries interchangeable ?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sorry no, The original Apple watch uses a different connector system for most everything and that includes the battery. See for your self here:
Original Battery
Series 1 & 2 Battery
Punteggio 4
**Editing to say that I am 100% sure you can swap batteries between the First Gen and Series 1 Apple watches because I’ve successfully done it countless times.**
I'm pretty confident that you can use a battery from a Series 1 Watch in an Original Apple Watch. The internals between the Original and the newer Series 1 are almost identical. (The processor was about the only change.) In fact, if you order a replacement battery from ifixit.com, the batteries are listed as being compatible with either Watch. Also, the details about the used OEM batteries listing even says that they are taken from either an Original or a Series 1 Watch.
Apple Watch (38 mm, Original & Series 1) Battery
[prodotto collegato mancante o disabilitato: IF308-010]
Series 2 is different though and cannot be used in the earlier models.
Immagine Apple Watch (38 mm, Original & Series 1) Battery
Prodotto
$16.99
Punteggio 2
Aggiungi la tua risposta
Sheila Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,250
