iPod Touch 5th generation stuck on logo.
I need your help, guys. My ipod touch 5th generation is stuck on logo. My home button doesn't work. What will I do? Itunes on computer can't read my ipod...
Questa è una buona domanda?
When a device is stuck on the Apple logo, the software is lost and doesn't know here to go. You need to put the device in recovery mode or DFU mode to successfully restore. Of course, you would need the home button to do so. A repair is a must for this device. Depending how the home button is damaged, depends on how difficult the repair is. If it doesn't click and appears stuck down, then the screen needs to be taken off and the black party of the home button clicked can be replaced without any soldering. If the button doesn't click but doesn't respond, then you have to take the device part and solder in a new home button flex cable which is not very easy. You can then put the device in recovery mode or DFU mode and perform a full restore to go back to normal.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,426
I can't help you without a working home button. So buy an iPod touch home button then install it then I can help you. iPod touch (5th Gen) Home Button / there is a tutorial on how to install it
da Jared Morgan
I wonder if 3Utools software can reboot the iPod touch to recovery while it's stuck on apple logo. It's worth a try because I know it can force a phone to reboot to recovery mode to do a firmware update even if it's not trusted via device to computer.
da Ben
The BootRun has probably crashed in the software So you would have to restore the iPod because when you restore a device it deletes the software the reinstall it. And you need a home button to do that or go through settings then iTunes
da Jared Morgan
I had one come in to my shop the other day with an issue like this and all it needed was to be plugged into a Mac computer and run the updates for it. I would try that before going into depth or replacing the device.
da Daniel Mason
