Salta al contenuto principale
Quinta generazione dello smartphone android al top di gamma Samsung, rilascaito l'11 aprile 2014. I miglioramenti rispetto alla serie successiva comprendono lo scanner impronte digitali, la fotocamera aggiornata, lo schermo più grande e la resistenza all'acqua. Disponibile in quattro colori differenti: nero, blu, bianco e oro.
577 Domande Visualizza tutte
In boot loop 5 or 6 times then goes black
Hi Guys.
OK i have a Samsung Galaxy S5 which has never had a screen replaced or ever been damaged.
When it was brought in it was just a blank screen the phone is on as i can hear when it rings gets messages ETC it also vibrates too.
I took the battery off so i could restart it it does start up & comes up with the Samsung Galaxy S5 start up graphic then loops sometimes 5 times sometimes 6 then the screen goes black.
When the screen goes black the buttons along the bottom light up fine when activated.
I can't tell if the backlight is on when its black i don't think it is.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hey Kenny, Ive run into the issue before ive found a temporary fix but it only works long enough to pull data off the phone the phone is pretty much screwed
Ive found that heating the proccessor with a heater for 8 minutes at 120C make sure you place the heat gun 3 inches above the chip and heat let cool and reassemble this has worked for me 90% of the time and will pull it out of boot loop for about a hour
Punteggio 1
1 Commento:
Hi Stephen thank you i will give that a go later & let you know how it goes.
da
It sounds like an issue with Android itself, it might be soft bricked. Did you try to flash/install something?
Punteggio 0
2 Commenti:
Don't think so she said she has never had anything done to it
da
Reading it over now, I see what you mean. Sorry, I must've misread the question!
da
Aggiungi la tua risposta
Kenny Leonard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 77
