Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Problem after changing charging IC
Hello everybody,
The iphone 6 plus battery started to drain, I tried everything from changing the battery and chargers to changing the U1700 ic chip which actually worked!
But unfortunately I couldn't connect it to a computer nor plug it in a charger, it works temporarily then turns off with apple logo loopinf when plugged in, i tried changing the ic chip twice and the problem hasn't been solved, anyone has any solution for this frustrating problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Its possible You damaged additional components when replacing the charging ic have you tested the Components next to the charging ic for damage?
Punteggio 0
i have iphone 6 plus charging not working i change u2 ic but not working
please help me
Punteggio 0
1 Commento:
i have iphone 6plus not charging i change u2 ic but still problem plss help me
da
Aggiungi la tua risposta
Yousef sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,574
