Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Mic is not working properly, even after replacing
My iPhone 6 mic not delivering full voice to other , compare to other iPhones only 50% voice other can hear compare to other iPhone.
I also replace mic , along with full card with which mic is attached.
What to do ., how it get solved
Questa è una buona domanda?
Punteggio 0
2 Commenti
Have you checked the speaker filters and cleaned them?
da
Is after changing logic board problem get solved
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I've just had the same problem on the same iPhone model. Took the same steps and replaced the dock but without any result at all. Checked the connector on the board under a microscope and it shows no damage.
Full restore didn't bring any result either.
Unfortunately I came to the conclusion that is a logic board problem, some component went bad and needs deeper diagnostic and high microsoldering repair skills.
Punteggio 2
Aggiungi la tua risposta
Maninderjit Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 67
