How to replace bushings and struts
turn steering grinding noise I have new rack & pending (maybe bushing) and struts need to be replaced bumping up and down. can you give replacing info?
Questa è una buona domanda?
greg.proctor48 , The grinding noise you here is probably the strut bearings seized, which may have even broke a front spring or check power steering pump for fluid level or if noise coming from there. Below 1st link video is a CRV showing the process of changing front strut assy, 2nd link is a similar strut being removed but better quality video. 3rd link shows trouble shooting front end noise. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=4GCNJyJ-...
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 119
