Salta al contenuto principale
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
20 Domande Visualizza tutte
Tablet shuts down while playing games
Tablet shuts down while playing games. Tablet also will not open games app. - just closes automatically. Comes up with a box that says Thermal Shutdown. Thermal critical error occurred.
Questa è una buona domanda?
Punteggio 3
3 Commenti
How do I fix this problem
da
Check the chosen answer for what you’re looking for.
da
how do i fix this on amazon kindle fire gen. 5
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your tablet is overheating.
If your tablet is in case, try taking it out. I have the same tablet and it tends to get hot and shut down.
Also, try some type of cooling pad or something that will allow air to get to the underside . That should help remove any build up of heat around it.
If it is heating up right after starting up, then you may have some internal problems. You might want to look into having someone look at it or finding a new tablet.
Good luck.
Punteggio 1
Aggiungi la tua risposta
Brenda Fulton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 847
