Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
425 Domande Visualizza tutte
Black smudge in the LCD a day after glass replacement
Yesterday I finished the glass replacement of a G930 and everything worked fine. Today, after I installed the assembly back onto its frame it turned on with a huge black smudge. The alignment was done with a universal mold and I used LOCA. Connectors are clean, flex looks fine.
What is there to do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
After some research I have found out that the black smudge is actually all the dead pixels. What "killed" them is the LCD being put under tension, not pressure. A drop can cause this. This only happens to AMOLEDs. Hope I helped someone.
Punteggio 0
Aggiungi la tua risposta
Ciprian R sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 54
