Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
No cellular service, very weak wifi, no water problems.
My iPhone 6 lost cellular service (No service) and it has very week wi-fi reception (2 bars when next to router - none with a wall in between). I've replaced SIM without success; SIM works on other phone. Phone hasn't been in water, but a light drop on top left corner that chipped glass. Can the antenna go bad or become disconnected? Any other possibilities?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Thanks you so much! Is the baseband chip replaceable? I'll check wifi connections later.
da
that chip is specific to each motherboard, the solution would be reballing the chip. A micro soldering job, a little bit more complicated.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The wifi antenna disconnects sometimes due to shocks but only way to see that is by removing the motherboard from the phone and check the connection.
For the cellular part you can do a quick check by dialing *#06# if the IMEI n* shows is the antenna if doesn't show then you have a baseband chip issue.
Punteggio 3
Aggiungi la tua risposta
craiger1528 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 78
