Salta al contenuto principale
The Singer EZ-Stitch Chainstitch Sewing Machine is meant to help beginners create their own fun and creative projects. It can be used to assemble crafts, clothing, pillows, accessories, and more.
7 Domande Visualizza tutte
How do I make it stitch? the peal works, the needle moves, no stitches
and yes, i threaded the needle, and it is all looking fine, but when i try to sew, nothing stays. the needle goes in and out and the thread trails uselessly behind.
is there anything to do about this?
peace
K
Update (03/22/2017)
this machine does not have a bobbin. it also came with no instruction manual.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
stroicielka, The video link below are the instructions to ensure you are setting it up correctly and shows how to thread properly. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=hZMjVYQs...
Punteggio 2
Have you threaded the bobbin or thread it correctly? Check your manual for proper procedure on this
Punteggio 1
a very important tip for bobbins is the direction that you must follow the instructions for the directions in which the bobbin unwinds!
Punteggio 0
Aggiungi la tua risposta
stroicielka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 684
