Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Half black and static lines on new SE screenshots​
Has anyone else had issues repairing the screens on the SE? It seems that the screens all have the same issue - static lines and exactly half black screens. Thanks for any feedback!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Are you putting the screws back in the same spots?
da
Yes. Do you mean the screws that hold down the metal shield over the screen connectors?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Even if they say the screens for IPhone 5S are interchangeable with the SE that is not always true.
If you have some old batch of IPhone 5s screens that could be your problem.
Some screens work some don't.
Be careful also to the front mic , SE one is different than the one in 5S.
Punteggio 3
2 Commenti:
Hmmm ok thanks. I guess that makes sense. I'm not following about the front mic though. Does that get changed out with the screen, or are you just stating that it's a difference? Thanks again for responding!
da
that is a difference also
da
You have to use the front camera microphone assembly from the old SE screen to the new screen. Can't use a 5S front camera assembly as the microphone pinouts are different.
Also you can only use Aftermarket SE screen, Original SE screen, Original 5S screens on the iPhone SE.
Aftermarket 5S screens will cause LCD display errors if used on a SE.
Punteggio 3
2 Commenti:
Thanks! So where does one purchase the 5SE screens for replacements?
da
Some say here is a good place to buy [prodotto collegato mancante o disabilitato: IF124-049]
da
Aggiungi la tua risposta
Erika Cuellar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 134
