Salta al contenuto principale
Toshiba laptop from 2011. This laptop came with a Celeron, Pentium, Core i3, Core i5 or Core i7 processor.
20 Domande Visualizza tutte
How I disable the fn key on my laptop?
I have to press the fn key to use the space bar and couple other keys. how can i fix that?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@alex63 ,alex , If board seems worn/damaged, it may be time to replace the key board, below is a link #1 guide to show how to disassemble your laptop to enable the changing of keyboard less then $20.00 in the 2nd link. If you think it could be because of malware or virus you will have to do a scan and get rid of it. You could also try a restore back to a point earlier when all was running well. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.irisvista.com/tech/laptops/To...
http://www.laptoppartstore.com/replace--...
Punteggio 1
See if you turned on "FN Lock".
For windows 7:
Run the HW Setup program by clicking Start -> All Programs -> TOSHIBA -> Tools & Utilities -> HWSETUP.
The HW Setup dialog contains a number of tabs. Click the "Keyboard" tab.
If Special Function Mode and Standard F1-F12 Mode choices are presented, select Select Standard F1-F12 Mode. If the Special Function Mode and Select Standard F1-F12 Mode choices do not appear, your particular Toshiba laptop does not need this adjustment.
Click Ok
Close the HW Setup program.
For Windows 8/8.1/10:
http://www.mytoshiba.com.au/support/item...
Punteggio 1
Aggiungi la tua risposta
alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 13,590
