Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Can I install Server SSD 2.5inch SAS Drive into MacBook Pro 13” 2012
I would like to enquire i just boughtSanDisk 1.6TB LB1606R Lightning Read-Intensive 6Gb/s SAS 2.5" SSD, MLC, Up to 410MBs Throughput, 3 Year Warranty
i wanna know the PROs & CONs...
https://www.corporatearmor.com/product_i....
My question is ..is it possible for me to install it into my MBP 13” 2012 2.9ghz i7?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Here's some good reading on the different drive interfaces: Understanding SCSI, ATA, SAS and SATA
da
This drive is intended for large server systems not desktop or laptop systems. I would recommend you return it and get your money back as just isn't anyway to use it here.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You MacBook Pro uses a SATA interface so no you can't use this SAS drive as it's not compatible.
Instead you could go with either of these two drives:
  • Samasung 850 EVO. They offer both a 2 TB & 4 TB drives. Samsung also offers an ultra large 16 TB SSD as well (well beyond what most people would need)
  • Crucial MX300 The largest they offer is a 2 TB
Neither SanDisk, Kingston or Transcend don't offer anything larger than 960 GB in 2.5" SATA
The SanDisk drive you listed is quite expensive! Why do you think you need such a drive? Maybe we can offer you some other alternatives.
References:
Punteggio 2
Aggiungi la tua risposta
khaidir77 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 616
