Jack is bent, is there any way to fix it?
The jack on my turtle beach headset is bent, is there an easy way to fix it or somewhere I could take it to get fixed?
Questa è una buona domanda?
the piece that is actually bent , is down inside the molded boot of the cable. there are replacement three ring 3.5mm jacks that you could, replace that one with, if you can solder.
OR, i am sure any local computer / phone repair shop would be able to put a new jack on that for you.
Hey um how much does that usually cost?
Yes there is a way you just bend it back it won’t brake it or anything it will be back to normal.
I have the same problem but I tried it but it never worked
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,449
1 Commento
I have the same problem. I was listening to music when I dropped my phone sideways and the wire bent. I currently can’t afford new turtle beach headphones so I’m using them while it’s bent. If anyone can fix this god bless them
da Gian Grosso
